In Rhino Inside Revit (RIR), I can only select one dimension type. When I choose another, the previous dimension disappears. Is this a bug?
Not seeing any issue here with a simple test. Can you provide an example? Thanks
going through the Right click set…
I imported lines from Rhino into Revit to create detail lines for dimensioning. However, I found that changing the dimension type doesn’t work. This is my Grasshopper file.
dimension type.gh (20.8 KB)
The values shouldn’t be zero; it seems like it’s not functioning correctly.
Swapping the Types is functioning as expected. When a get a chance i will look at the rest of your definition setup.
Its functioning correctly.
If you manually place a dimension string and check its Annotation References you will see 4 points. Your dimension is referencing the Curves.
Here i used points to create the Dimension String.
re_dimension type.gh (18.7 KB)
Thank you, I understand what’s going on now.
