I am currently using rhino 6, it had a macro that worked correctly; but now I don’t understand why it fails.
from the macro the function Untrimmed Meters refuses to work.
!_Circle _AroundCurve
_SelPolyline _pause _pause
_SelPolyline
-_sweep1 _SelCrv _SelClosedCrv UntrimmedMiters=Yes _enter _enter _enter
poly.3dm (34.2 KB)
pascal
(Pascal Golay)
April 2, 2020, 5:03pm
2
Hello - try:
-_Sweep1 _SelPolyline _SelClosedCrv _Enter _Enter _UntrimmedMiters=Yes _EnterEnd
There needs to be input for setting the seam on the closed curve.
still not working, only works if I previously activate Untrimmed Meters from the sweep1 command popup
this is what i try to say
pascal
(Pascal Golay)
April 2, 2020, 5:21pm
4
Hello - this
_SelPolyline
-_Sweep1 _SelClosedCrv _Enter _Enter _UntrimmedMiters=_Yes _EnterEnd
works here, from end to end,in your file, if I delete the existing circles first.
Interesting this if it works, I understand where is the problem “_Yes”; it’s weird but before it worked without that underscore.
Thank you @pascal
pascal
(Pascal Golay)
April 2, 2020, 5:28pm
6
Hi Vikthor - are you running Rhino in English? If so the underscore should not matter - if not, then, yes…
I have always used rhino in Spanish, suddenly it stopped working in one of his updates
