Does anyone have a good technique for modeling the plating on a riveted hull?
I have data points for the visible plating edges. Some of the plating strakes go inside the modeled line. So go on the outside. In some other locations plates cross the molded line. The plate need to be bent at the edges where there is an overlap.
