How to use HistroyRecord Class?
I am trying to execute HistoryRecord
public HistoryRecord(
	Command command,
	int version
I wanted to know what command does it need and what does the version stand for.
I was looking at the Rhinocommon API but it does not explain what these inputs mean and how to provide them.
Any leads or an example will help a lot.
Thanks
@Mahdiyar , Thank you , this was a good reference and it helped me understand the use of historyrecord. It seems that we need to have a command from rhino to make use of it even from Grasshopper.
@bobmcneel & @dale , I have been trying to implement a custom Ordinate Dimension class and currently function to AddOrdinateDimension to Rhino is based on this function
public Guid AddOrdinateDimension(
	OrdinateDimension dimordinate,
	ObjectAttributes attributes,
	HistoryRecord history,
	bool reference
Can we not have it like other Dimension classes, where we only need
	ObjectAttributes attributes)
How about just doing this?
var dim_id = doc.Objects.AddAngularDimension(dimension, attributes, null, false);
– Dale
Hi @dale ,
Thank you , that worked.
