Hi!
What’s the component to ‘filter’ and work only on a subset of vertices of a polygon mesh?
I’d like to scale only part of the mesh, without creating a second mesh. The list of vertex IDs I have.
I’d know how to write a Python component for that, but better ask before…
Hello!
The part of the mesh I want to work on cannot simply be surrounded by any simple shape.
But I think I get the idea now…
‘DeconstructMesh’ > split the vertex list into a part that will be transformed and a part that remains using ‘Sub List’ > combine the 2 vertex lists again > ConstructMesh
However, I think I’ll better do this with a few lines of Python code.
if it’s not a free form shape you can bundle a whole bunch of Breps (and evaluate Point Inclusion for every each one of them…) to cover the shape/part you want to “capture” from the original mesh.
You can access the vertices of a mesh and set a vertex like so in RhinoCommon using GHPython (note that this method has three other overloads i.e. different signatures/ways of setting the vertex). Make sure to pass your mesh to the GHPython component as a Mesh (right-click component -> Type Hint -> Mesh) to directly access the vertices using the dot notation syntax i.e. MyMesh.Vertices.SetVertex(indexOfVertex, newPosition)
