I want to switch doc.objects between display and hidden.
It is Ok to switch from display to hidden, but I can’t get the hidden object in the doc.objects after then,
so it fail to switch back from hidden to display.
How to solve it?
public class MmaTest : Rhino.Commands.Command
public override string EnglishName { get { return "mmaTest"; } }
bool visible = true;
protected override Rhino.Commands.Result RunCommand(RhinoDoc doc, Rhino.Commands.RunMode mode)
if (visible == true)
foreach (var obj in doc.Objects)
doc.Objects.Hide(obj, false);
visible = false;
else
foreach (var obj in doc.Objects) //get obj fail!!!
doc.Objects.Show(obj, false);
visible = true;
doc.Views.Redraw();
return Rhino.Commands.Result.Success;
