doc.Objects only Viewport dependent, does not retrieve hidden rhObj
I wanne retreive all RhinoObjects that are currently hidden in the Viewport (done via the Hide Command), but the problem is that doc.Objects cant event find those objects.
Am I using the right tool, here?
The idea is, that we wanne give the user feedback, about objects that are hidden and have UserDefinedData.
This was a first test, using C#7.3:
using Rhino;
using Rhino.DocObjects;
using Rhino.Commands;
using System.Collections.Generic;
public class GetHiddenObjectGuids : Command
    public override string EnglishName => "GetHiddenObjectGuids";
        List<System.Guid> invisibleObjectGuids = new List<System.Guid>();
        List<System.Guid> allObjectsGuids = new List<System.Guid>();
        foreach (RhinoObject obj in doc.Objects)
            allObjectsGuids.Add(obj.Id);
            bool isHidden = obj.IsHidden;
            bool isOnHiddenLayer = !doc.Layers[obj.Attributes.LayerIndex].IsVisible;
            if (isHidden || isOnHiddenLayer)
                invisibleObjectGuids.Add(obj.Id);
        foreach (var guid in invisibleObjectGuids)
            RhinoApp.WriteLine($"Invisible: {guid.ToString()}");
        foreach(var guid in allObjectsGuids)
            RhinoApp.WriteLine($"Not Invisible: {guid.ToString()}");
        return Result.Success;
Hi @Benterich,
Use a ObjectEnumeratorSettings object.
SampleCsObjectEnumerator.cs
– Dale
That worked amazing! Thank you I didnt know about it :)!
This is how I updated it for anyone who is interested:
    var settings = new Rhino.DocObjects.ObjectEnumeratorSettings
        HiddenObjects = true,
        LockedObjects = false,
        NormalObjects = true,
    var objectList = doc.Objects.GetObjectList(settings);
    foreach (RhinoObject obj in objectList)
    // Print the results
    foreach (var guid in allObjectsGuids)
        if (!invisibleObjectGuids.Contains(guid))
