how to sort rejoindre point to polyline
and the direction to center?
like this? point to polyline_ME.gh (47.6 KB)
cool !!! Thank you for your reply, maybe there is a little problem with my method.
because I want to do the same effect as this picture, but now I may also need a different way
Your first attempt: I think you are trying to deform the base form locally. I’ve adjusted your gh-file: a lot of unnecessary duplicate points were created, this way you avoid that. point to polyline_MEV2.gh (30.3 KB)
Thank you very much !!! This is exactly what I want!
Hello, I would like to add curve interference to my previous solution to influence the morphology with randomly generated curves, but I can never connect to the last step, I hope you can help me, thank you very much!!!
2020-12-18 point to polyline.gh (39.1 KB)
thank u very much !!! maybe i can use dispatch " true true false "
cooool !!! i will see that
