When I use Surface Split, the buttton turns red. It seems like the surface cannot be split. What is the problem?
1.3dm (207.2 KB) 1.gh (509.6 KB)Hovering on the F output of the Surface Split component tells me something is wrong with path {6}
Some of your curves have self-intersections. Actually you have more self-intersections, also on other surfaces.
This should be some circle I generated with grasshopper. I tried the same coding with other surfaces and it works well. Only the 6th path goes wrong. What is the problem of it?
