Hello all,
For technical drawing purposes I would like the set the base point of triangular hatches within Grasshopper. As an example I have the rectangles in the image below, where I would like to set the base point in Grasshopper to the indicated corners.
I’m aware that there is a possibility to change the hatch attributes using C# (https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.hatch/basepoint) . Sadly my C# is not yet of a sufficient level to solve this myself so far.
My question: is it possible to adjust the hatch attributes such as the base point within C# and how to do this?
A MWE example is added, I’m using Elefront to create the hatches and do the baking.
MWE_hatch_properties.gh (10.0 KB)
Thanks!
