Hi i try to get hatch boundry in hatch in rhino by grasshopper
But i don’t know select hatch in Rhino and (set)
that (import hatch )in grasshopper please help me and What is hatch input in c# component?
For example is hatch geometry Base data or ???generic data ,…
Hi @Rh-3d-p,
Is this helpful?
import Rhino
import scriptcontext as sc
def test_hatch_boundary():
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select hatches")
go.GeometryFilter = Rhino.DocObjects.ObjectType.Hatch
go.GroupSelect = True
go.SubObjectSelect = False
go.GetMultiple(1, 0)
if go.CommandResult() != Rhino.Commands.Result.Success: return
for objref in go.Objects():
hatch = objref.Hatch()
if hatch:
curves = hatch.Get3dCurves(True)
for curve in curves:
sc.doc.Objects.AddCurve(curve)
sc.doc.Views.Redraw()
if __name__ == "__main__":
– Dale
Hi thanks
But i don’t need use scriptcontext and python
I need to slove in c#. For write plugin .
The code for C# plug-in command isn’t much different.
var go = new GetObject();
go.SetCommandPrompt("Select hatches");
go.GeometryFilter = Rhino.DocObjects.ObjectType.Hatch;
go.GroupSelect = true;
go.SubObjectSelect = false;
go.GetMultiple(1, 0);
if (go.CommandResult() != Rhino.Commands.Result.Success)
return go.CommandResult();
foreach (var objref in go.Objects())
var hatch = objref.Hatch();
if (null != hatch)
var curves = hatch.Get3dCurves(true);
foreach (var curve in curves)
doc.Objects.AddCurve(curve);
doc.Views.Redraw();
return Result.Success;
– Dale
hi @dale again
If I want to run in Grasshopper
What should I enter in the using section so that it does not give an error?
error
Error (CS0115): 'Script_Instance.RunCommand(Rhino.RhinoDoc, Rhino.Commands.RunMode)': no suitable method found to override (line 63)
hatch boundray.gh (10.8 KB)
@Mahdiyar
You might consider using the hatch object GUID to reference it in Grasshopper like this.
private void RunScript(Guid id, ref object Outer, ref object Inner)
var rhinoObject = RhinoDocument.Objects.FindId(id);
if (rhinoObject is HatchObject)
var hatch = rhinoObject.Geometry as Hatch;
Outer = hatch.Get3dCurves(true);
Inner = hatch.Get3dCurves(false);
import Rhino
rhino_object = Rhino.RhinoDoc.ActiveDoc.Objects.Find(id)
if type(rhino_object) is Rhino.DocObjects.HatchObject:
hatch = rhino_object.Geometry
Outer = hatch.Get3dCurves(True)
Inner = hatch.Get3dCurves(False)
HatchBoundary.gh (7.4 KB)
