My system is Rhino 6 C++ SDK.
I want to design custom view background in my plugin.
How to set the Display mode to Rendered and set the Background to Gradient 2 Colors by API function at CMyRhinoEventWatcher::OnInitRhino ?
Hi @john12,
Rather than modify Rhino’s Rendered display mode, you might consider making a copy of it and modifying it to your liking. Then, when the user opens a new file, set the custom display mode to whatever view’s you want.
Does this help?
– Dale
This is my code.
ON_UUID display_id = ON_StandardDisplayModeId::Rendered;
CRhinoView* pView = RhinoApp().ActiveView();
pView->ActiveViewport().SetDisplayMode(display_id);
pView->Redraw();
This result is to set Display mode to Render.
But I don’t know how to set Background to Gradient 2 Colors, Top, and Bottom color.
Please give me a sample.
Hi @john12,
From a command you can do something like this:
CRhinoCommand::result CCommandTest::RunCommand(const CRhinoCommandContext& context)
const ON_UUID display_mode = ON_StandardDisplayModeId::Rendered;
DisplayAttrsMgrListDesc* pDisplayAttrs = CRhinoDisplayAttrsMgr::FindDisplayAttrsDesc(display_mode);
if (nullptr != pDisplayAttrs)
CDisplayPipelineAttributes* pAttrs = pDisplayAttrs->m_pAttrs;
if (nullptr != pAttrs)
pAttrs->m_eFillMode = EFrameBufferFillMode::FBFM_GRADIENT_2_COLOR;
pAttrs->m_GradTopLeft = RGB(0, 50, 102);
pAttrs->m_GradBotLeft = RGB(165, 165, 165);
pAttrs->m_GradTopRight = pAttrs->m_GradTopLeft;
pAttrs->m_GradBotRight = pAttrs->m_GradBotLeft;
CRhinoDisplayAttrsMgr::UpdateAttributes(*pDisplayAttrs);
CRhinoDisplayAttrsMgr::SaveProfile(RhinoApp().ProfileContext());
context.m_doc.Regen();
return CRhinoCommand::success;
– Dale
This should do it:
import System
import Rhino
import scriptcontext as sc
id = Rhino.Display.DisplayModeDescription.ShadedId
description = Rhino.Display.DisplayModeDescription.GetDisplayMode(id)
if description:
attributes = description.DisplayAttributes
if attributes:
top = System.Drawing.Color.FromArgb(0, 50, 102)
bot = System.Drawing.Color.FromArgb(165, 165, 165)
attributes.SetFill(top, bot)
Rhino.Display.DisplayModeDescription.UpdateDisplayMode(description)
sc.doc.Views.Redraw()
– Dale
Hi @dale,
When I test in Rhino 6, it is not work well.
Message: ‘DisplayPipelineAttributes’ object has no attribute ‘SetFill’
How can I do?
Update to the latest service release of Rhino 6.
– Dale
OKay. It works well. Thanks
