How to save .gh file directly from python component?
Hi All,
I wonder if it’s possible to save a .gh file (with custom filename in a pre-selected dir) directly from gh python component.
Thank you in advance for all your tips.
Save the file you’re in? Or some file you made up on the spot?
Either way the best way forward is probably the GH_DocumentIO class. It allows you to save and read memory and file based documents.
Thank you David,
I mean the file I am in and perform from gh python component the script that executes this command:
01
Yeah, GH_DocumentIO is what you need. Don’t know how it would look in python, but in C# the code is like this:
      var io = new GH_DocumentIO(GrasshopperDocument);
      io.SaveAs();
Something like this should do it:
import Grasshopper as gh
io = gh.Kernel.GH_DocumentIO(ghenv.Component.OnPingDocument())
io.SaveAs()
Perfect! Thank you so much, David and Anders.
I will try!
