why it makes a mistake?
Hi @1351648725,
Look closely at this line:
RhinoApp().RunScript(L“_-Line 0,0,0 10,10,10”, 0);
Notice the typographic (e.g. curly, curved, book, or smart) quotation marks? These Unicode characters (0x201c, 0x201d) are not valid delimiters for string literals.
In C++ the enclosing delimiters for string literals are ASCII (0x22) double quotes. For example.
RhinoApp().RunScript(L"_-Line 0,0,0 10,10,10", 0);
Hope this helps.
– Dale
it didn’t work. and why there is no error in line76 ?
Rather than post a script shot of your code, which doesn’t help in any way, can you post your source code instead?
– Dale
after creating a plugin project,just three operations were performed.
- delete the line with “#error…”
- change the class of plugin12 into CRhinoScriptCommand which showen in the picture
- add a command in line 69(in picture2)
Without any more information than you’ve provided, I am guessing that you don’t have all of the necessary C++ components for Visual Studio installed.
You might consider re-running the Visual Studio installer and make sure you have all required C++ components installed.
– Dale
change:
into:
CRhinoScriptContext s = CRhinoScriptContext();
s.SetScript(L"_-Line 0,0,0 10,10,10");
RhinoApp().RunScript(s);
the problem has been solved with someone’s help.
thank you for help.
– Dale
