Problem with command's parameters in RhinoApp.RunScript() method
In my C++ SDK plugin, the “Line” command with “0,0,0 10,10,0” as start/end coordinates parameters is called. The problem is that my plugin always skips parameters after “-_Line”, as depicted in the screen capture below. I tested RhinoApp().RunScriptEx(doc_sn, L"-_Line 0,0,0 10,10,0", nullptr), RhinoApp().RunScript(doc_sn, L"-_Line 0,0,0 10,10,0"), RhinoApp().RunMenuScript(L"-_Line 0,0,0 10,10,0"), without any improvements.
Rhino8_MakeLine_10
Here follows my C++ code:
CRhinoCommand::result CCommandMakeLine_10::RunCommand(const CRhinoCommandContext& context)
  // CCommandMakeLine_10::RunCommand() is called when the user
  // runs the "MakeLine_10".
    unsigned int doc_sn = context.Document()->RuntimeSerialNumber();
    RhinoApp().RunScriptEx(doc_sn, L"-_Line 0,0,0 10,10,0", nullptr);
    context.Document()->Redraw();
  return CRhinoCommand::success;
Could you help me to solve this problem ?
Thanks in advance.
Best regards
Gilles
Is your command a script-runner command? If not, you need to inherit from CRhinoScriptCommand instead of CRhinoCommand.
My command is a C++ plugin. It inherits from CRhinoUtilityPlugin.
It has been constructed using the Rhino SDK. In Visual Studio 2022: Menu File > New Project > Rhino 3D Plugin (C++ ) “Build plug-ins for Rhino using the C++ SDK”.
Here follows the header:
// MakeLine_10PlugIn.h : main header file for the MakeLine_10 plug-in.
#pragma once
// CMakeLine_10PlugIn
// See MakeLine_10PlugIn.cpp for the implementation of this class
class CMakeLine_10PlugIn : public CRhinoUtilityPlugIn
public:
  // CMakeLine_10PlugIn constructor. The constructor is called when the
  // plug-in is loaded and "thePlugIn" is constructed. Once the plug-in
  // is loaded, CMakeLine_10PlugIn::OnLoadPlugIn() is called. The
  // constructor should be simple and solid. Do anything that might fail in
  // CMakeLine_10PlugIn::OnLoadPlugIn().
  CMakeLine_10PlugIn();
  // CMakeLine_10PlugIn destructor. The destructor is called to destroy
  // "thePlugIn" when the plug-in is unloaded. Immediately before the
  // DLL is unloaded, CMakeLine_10PlugIn::OnUnloadPlugin() is called. Do
  // not do too much here. Be sure to clean up any memory you have allocated
  // with onmalloc(), onrealloc(), oncalloc(), or onstrdup().
  ~CMakeLine_10PlugIn() = default;
  // Required overrides
  // Plug-in name display string. This name is displayed by Rhino when
  // loading the plug-in, in the plug-in help menu, and in the Rhino
  // interface for managing plug-ins.
  const wchar_t* PlugInName() const override;
  // Plug-in version display string. This name is displayed by Rhino
  // when loading the plug-in and in the Rhino interface for
  // managing plug-ins.
  const wchar_t* PlugInVersion() const override;
  // Plug-in unique identifier. The identifier is used by Rhino for
  GUID PlugInID() const override;
  // Additional overrides
  // Called after the plug-in is loaded and the constructor has been
  // run. This is a good place to perform any significant initialization,
  // license checking, and so on.  This function must return TRUE for
  // the plug-in to continue to load.
  BOOL OnLoadPlugIn() override;
  // Called one time when plug-in is about to be unloaded. By this time,
  // Rhino's mainframe window has been destroyed, and some of the SDK
  // managers have been deleted. There is also no active document or active
  // view at this time. Thus, you should only be manipulating your own objects.
  // or tools here.
  void OnUnloadPlugIn() override;
private:
  ON_wString m_plugin_version;
  // TODO: Add additional class information here
// Return a reference to the one and only CMakeLine_10PlugIn object
CMakeLine_10PlugIn& MakeLine_10PlugIn();
That all looks good, but you also have a command of which you showed the implementation earlier, and what I meant was the inheritance of that CCommandMakeLine_10 command.
You should have something like this:
class CCommandMakeLine_10 : CRhinoScriptCommand // <-- inherit from CRhinoScriptCommand, not CRhinoCommand
  // command declaration and definition comes here
@menno : Thank you very much! It works.
