downloaded the STEP file for the goBILDA 2808 Series Stainless Steel Threaded Rod (M4 x 0.7mm, 150mm Length) from 2808 Series Stainless Steel Threaded Rod (M4 x 0.7mm, 150mm Length) - 2 Pack - goBILDA® , but it’s too complex and is slowing down rendering. Do you have any suggestions for simplifying it?
We just introduced RhinoAI in RHino 9 Beta. And I have it is great at defeaturing objects based on the model type.
So with the model from the link above, I promted AI Astra
This is a stainless threaded rod. I need a simplified NURBS mode that is a cylinder for the length with 45 degree chamfer at each end just like the stainless rod.
It responds with:
The rod is 4 mm in diameter and 150 mm long. I’ll match its end-face diameter with 0.709 mm × 45° chamfers, and keep the threaded original hidden for reference.
And you can see the model below next to the original model downloaded.
Really amazing technology. There is more about feature recognition and simplifying models with AI in this post: Experiments: using AI to infer model features, then model from them
