How to Pack Irregular Tree Branch Meshes Into a Solid Column
Hi everyone,
I’m working on a material reuse project where I scanned real tree branches using photogrammetry and converted them into mesh geometry. After cleaning up the meshes, I now have open-mesh models of these irregularly shaped branches.
My goal is to assemble these branches as densely as possible to form a column-like structure, and fill the remaining voids with other material (e.g., resin, infill, etc.) to create a solid, structurally usable element.
The challenge is:
  • The branches are not straight or uniform—they are curved and organic, which makes close-packing extremely difficult.
  • I want to find a way in Grasshopper to pack these meshes together with minimal gaps.
  • This feels similar to a 3D bin-packing or nesting problem, but most solutions I’ve found are either 2D-based or not suited for organic geometry.
I’d love to hear if anyone has encountered similar workflows or can suggest any plugins, strategies, or even optimization approaches (Galapagos? Kangaroo? others?) that could help.
Thanks in advance for your insights!
For reference, I’ve uploaded the mesh and test files here (due to file size):
200 mb download ?
post a screenshot please, so people know what to expect.
(1)
postprocessing the scanned data is the first step. Rhino is not the most powerful software for this. shrinkwrap might help. Make sure the meshes are closed - this will allow more workflows to play with. Create a low resolution version to find the position and to experiment.
If you have a workflow that suits - you can try if it works with the higher resolution. Or just replace the data after the position is found.
(2)
there are a few topic about 3d-nesting - not a 100% match but maybe a starting point:
(2b)
search for a service or specialised software that does the 3d-nesting / maybe use the trail version.
Thank you!
and the volume you want to pack them in ? a box / board ?
maybe do some research how traditional craftsmen handle this issue when they build a log cabin ?
want to pack them in a column
→ Kind of
Consider the order for something like this, perhaps pack the large objects first? Like this old analogy:
In past I did look a couple of episode of living/building in the wild (discovery channel? ) where they build a cabin from tree/logs.
As I rembember they did this:
  • placed two vertical poles (a bit smaller trees/logs) in the ground
  • they looked at the log, decided what side would be laying on the ground.
  • if bumps where sticking out, they were cut off with an axe
  • and placed against the vertical poles.
  • the second log, was turned around untill the curving would fit the best with the first log.
  • the axe was used for adjusting an the log was placed on top of the first and against the vertical poles
    No rocketscience:
  • 1 a couple of lines to place the mesh against
  • 1 a long rectangle box, to fit your mesh in, (top and down side all what sticks out, cut it off), so you a mesh flattened on top and bottom side. Not too much, but just a bit to get a better fit.
    and so on.
Second method:
  • cut all logs in 1/2 (length), that gives a nice straight surface to build with,
  • a vertical channel is cut out to hold the vertical pole
  • place the flat side of 1/2/ log onto the vertical poles
  • the second half the same but:
    !! !/2 log higher and on the other side.
    Advantage: Completely sealed wall
Good luck, enjoy the new build house. Regards, Eef
