How to open a specific webpage in system's default browser?
Hi everyone,
I’d like to know if I could open a specific webpage by running the system’s default browser, exactly how Rhino’s “Help” command does.
I know that a Rhino script like:
_Run Chrome.exe
will run Chrome, but it might have several issues:
  1. I couldn’t get a URL to work, tried a few things. just got the browser to launch.
  2. It might not be the system’s default browser.
  3. I’m not sure that command could work cross-platform.
If this is not achievable in Rhino script I could also write a plugin and run the plugin’s command.
opening a URL in the default browser in windows should be easy, but then I’ll have to make sure it will somehow work for Mac as well.
Thanks for your help :slight_smile:
Roy.
Edit: as for my question, Graham’s answer below answers it, but eventually I went on to run the python script through my plugin, details below as well.
You can do this with a python script:
import webbrowser
webbrowser.open(r"https://discourse.mcneel.com/t/how-to-open-a-specific-webpage-in-systems-default-browser/109699")
Thanks for the quick reply and the answer.
It does work but now I wonder if there’s a way I could run that python script inside a plugin.
Yes probably, but would a simple RunPythonScript command be OK?
-_RunPythonScript "import webbrowser;webbrowser.open(r'https://discourse.mcneel.com/t/how-to-open-a-specific-webpage-in-systems-default-browser/109699/3')"
Thank you Graham,
That is the solution to the question I’ve asked and I guess that as a python script it would work cross platform, but actually my requirement has changed a little and I would like to show some information before I’d like to open the webpage.
So I do wish to know how and if it is possible to run a python script from my plugin.
Yes, see the PythonScript class in RhinoCommon
Thank you Steve.
If it would ever help anyone else:
PythonScript ps = PythonScript.Create();
ps.ExecuteScript(“import webbrowser; webbrowser.open(‘http://rhino3d.com’)”);
Plus you have a typo on this page and on this page, they say “localilation” :slight_smile:
