Especially in this case I want to move the number curves to z=0 how do I put this in the command line. Thank you!
In the Front view place a point at 0. Then select your curves and use _Align _Bottom, click on the point… (from memory). You might just be able to type “0” instead of placing and clicking on the point, I don’t remember now…
Huh?
If you only need to move planar curves you can select all of them, use _setpt, check only the Z coordinate and input 0,0,0. Bear in mind that this will flatten any geometry that is not in a paralel plane to XY. This feature is very useful when you want to draw in 2D (like a top plan view) but by mistake curve control points end up scattered all around the Z axis.
Yes! This is so useful. Thank you
