i have nested a lot of geometries in many small sheets.
Now i want to print these sheets wirth nested objects on it, to work on manually.
How it is possible to move the shets and objects together - for example on a Grid ->screenshot
I’d use the center points you have there to create a vector with component “Vector2pt”
(from your nested geometries to the grid center points) - I assume you have the same amount of points and that the order is already correct.
Then move your nested geometry there…
From what info I have, I can’t really say more yet !
