How to model this sand dune as one surface
How do I model a continous surface with a few of these sand dunes (see img below) appering on the surface. At the same time I want the part which I have hilighted in red to be cut through so you would be able to see through it.
Appreciate any suggestions!
Barchan
For the dune to be a continuous single surface I’d say you use multiple curves that define the shape of the dune. Something like intersections of the dune and the sand around it with vertical planes parallel to the direction of the wind. Then use Loft with “loose” option
sweep 2 rails ?
for example :slight_smile:
Untitled-1
i did something same last month :
model :
render:
I am not sure I understand do you mind doing a quick sketch of what you mean?
ok so sweep 2 rails but how is it possible to attach it to a plane so naturally like the model. 6b70f851b00789f812b1f6da9a93a09f4b2e6721
This:
Untitled.3dm (72.3 KB)
in order to get your shape you need to add more points and form the sand-wave
thank you that helped!
aha so basically you draw multiple sections of the sand dune and the flat sand at different levels and and then loft it.
but did you define the curve from plan view first
I made a simple case. What I did was think how many points I need to define the most curvy part of this wave. So I created a single nurbs curve with that many points along 0x axis. Then copy it over in Y direction in n number of times and I started moving points by pairs (so that the wave is symmetric).
You can do it differently, You can simply create a planar surface, rebuild it with n-number of U rows and m-number of V-columns. Then you just adjust play around with the points
say I have multiple surfaces with diff waves is there a way to stitch then together for cnc later?
I mean so its one continuous surface with no division.
The only way I see this happening is if you convert your multiple-surfaces into meshes then convert it in a single surface. But I can’t help you with this I know nothing about mesh
That’s not how models need to be prepped for CNC, they don’t need to be one surface. They just need to be “joined” together, that’s the whole point of NURBS.
They don’t need to be “one” surface for CNC, the different surfaces just need to be “Join”-ed into one polysurface.
If this was answered to me. I didn’t say this is how you do it for CNC. just how would you do it to be a single surface :slight_smile: Currently I have no knowledge about CNC preparations.
Not even in most cases. If surfaces overlap, most CAM programs will only cut the topmost surfaces, so you can ignore anything that is “underneath” and not have to try to trim/join anything (if you’re lazy)…
Well, yeah, just trying to not encourage utter sloppiness!
