How to make reference boxes along curve for morph boxing?
Blue marking in image below are indicators of the end of the boxes, not the definite things I want. I want to manage the end of boxes with frames. Or, I think that that is efficient.
It means some code tried to access a collection element beyond the size of the collection. It’s a reasonably common bug in code, looks like you’ll have to contact the developer of Pufferfish about it.
I think it is because the angles that are less than 45 degree or something. Michael Pryor is the developer, right? Or do I have to enter this problem to a other topic that is about the plugin pufferfish?
Because that version uses a pipe behind the scenes and pipes break at polyline angles to form a poly surface. The next version I have does not use pipes, however keep in mind using that curve wont make much sense as there will be many intersections once that curve is “thickened”
