Hi all. Looking to create a cube with spikes without making each one individually, and ideally have agency over the lengths of them. Example Below:
Input is much appreciated!
You might want to look into grasshopper, where you:
You could also look into making a block out of one pin, spread them over your cube. Then in case you adjust 1 block, all of them get changed.
Good morning, If you wanted to go about using grasshopper I’ve attached a simple definition to get you started. I imagine it’s not 100% what you want, but it’ll give you a good idea of what you can achieve. Spiky_Cube_Start.gh (10.2 KB)
