How to make a circle from a line?
how to make a circle from a line ?
A line is the shortest connection between two points.
I assume you wanted to ask how to make a circle from a curve?
Fit a circle to a curve?
You can either create a 3 point circle or divide the curve maybe 10 times or so and then use the command _Circle _FitPoints
not quite, you need to, like in a compass, extrude the body along a curve that is extruded along its axis
like this
That’s a revolution and the command is called _Revolve
Revolve | Rhino 3-D modeling (mcneel.com)
