Piotr
February 3, 2025, 11:31am
1
V8, rhino toolbar
How to bring points from the external file that are on the specific layer?
Banal in V7 using Human, but I can’t make it work in V8.
Certainly not as a Model Object.
It seems like the Import Content is not seeing points at all.
This is huge bug.
wim
(Wim Dekeyser)
February 3, 2025, 1:38pm
2
Hi Piotr -
From those two images, it’s impossible to know what you are doing.
It seems to work fine…
Piotr
February 3, 2025, 1:46pm
3
How can I see anything from the image you attached?
wim
(Wim Dekeyser)
February 3, 2025, 1:47pm
4
Don’t you see as much from that image as from the images that you posted?
Piotr
February 3, 2025, 1:49pm
5
Well
this text is easy to read:
this one doesn’t:
wim
(Wim Dekeyser)
February 3, 2025, 1:51pm
6
Cool. This should be better then.
Piotr
February 3, 2025, 1:58pm
7
Thanks Wim
Why is the equality filter not working in this case?
wim
(Wim Dekeyser)
February 3, 2025, 2:01pm
8
Hi Piotr -
That’s impossible to tell from your image. I can’t see what the key is set to.
Piotr
February 3, 2025, 2:04pm
9
Model Object / Layer / Name
What is your set to?
wim
(Wim Dekeyser)
February 3, 2025, 2:09pm
10
I suppose this thread could possibly have been 8 posts shorter if you had posted a 3dm and a gh file in the opening post?
