How to link 2 grasshopper files
Hello Everyone,
I have a question, I’m sure has easy solution, but I can’t find it. I have a Grasshopper master file with many different setups of a Building Energy simulation plugins (Ladybug tools). Since this is getting a bit big, I don’t want to building project there. I would prefer to model in a different file for each project. Then at the moment of simulation, I import/recall each building separately.
Is there any way to link/import/recall information (in this case a building model) to grasshopper from another grasshopper file? Or maybe a way around?
Regards.
Data Output and Data Input
Exactly!! I knew it was something simple, just called diferently in Grasshopper.
Thanks a lot @Joseph_Oster
Just be very careful about removing and/or renaming data “channels”, they are not name/value pairs and will behave badly if misused.
  1. I usually copy and modify Data Output components, esp. a ‘data version’ part of the filename, when making major changes to a list of data channels (remove or re-sequence).
  2. Then make a new Data Input component referring to the new filename version and manually transfer wires from the old Data Input to the new, one at a time.
Hi -
On Rhino 7, you could try the Hops component:
https://developer.rhino3d.com/guides/grasshopper/hops-component/
Hey Joseph,
do you know an alternative for the case that a script is used multiple times within a second cavas while feeding it with different blocks of data? :slight_smile:
I barely understand your question. Would have to see code. Have you considered Hops?
