Hi Rhino Gurus,
Is it possible to keep the ‘Layout Views’ fixed in the Clipping Plane properties menu? I’m hoping to speed up the process of assigning the ‘clipped view’ for each clipping plane.
I often have hundreds of clipping planes for the models and it can be such a daunting task to assign the clipped view for each clipping plane. Every time I select a new clipping plane, the properties panel would revert back to ‘Model Views’ by default and I had to manually click on the drop-list to switch over to the ‘Layout Views’ so that I can see all the clipped views for the Layout Viewports. Doing it over and over for hundreds of clipping planes can be very time consuming and frustrating.
In Rhino 8, the process isn’t any better because every time I select a new clipping plane, the list would collapse, and I would need to re-expand the list again for each Layout Page to see the clipped views.
Any advice and suggestions for Rhino 7? Please see diagram below to illustrate my point.
Thanks for your time.
