Hi, i would like to know how to join these 2 surfaces of this front hull boat
what are the steps to follow ? thanks
Hi Emile - do you mean Join as in Rhino’s join command or ‘bridge across’ a gap so that the edges match? As I see it so far, you’re asking how to build a transition there - the smaller surface(s) between the larger ones above and below. Please post a file…
thanks for you answer; but i think i it is less obvious than that
have a look with zebra analyse :
emile
You could try with variableoffsetsrf - keeping tangency on one side. Then after - edit the non tangent side to your wish.
Hi Emile - you have multiple surfaces coming together at all angles, none smoothly, here:
If that is not what you intend, I’d fix that first - what do you intend there? Smooth along all edges?
Without knowing a bit more, I’m just guessing, but an arrangement something like what is in this file may do-
WALLY 118_PG.3dm (439.4 KB)
