How to inter-divide curves each other
here is the example
how to use grasshopper to inter-divide them?
Check this out…
ShatterMultiple_re.gh (14.9 KB)
There is also a component for that in this plugin
Another way.
GHdiscourse_shatter-crv.gh (10.0 KB)
@laurent_delrieu
Good to know, thanks…:smile:
The Shatter component is pain in the ass. It is very difficult to make it work in some more complex cases. I can’t understand why you can’t simply intersect the split at the points of their intersections.
yes! i have used the mutiple curve to get the intersect points but i get bunch of points.
by contrast with using plugin, I learn more from your solution
thx a lot! can’t appreciate more.
this is a very efficient way!
thanks a lot!
thanks for you works.
so glad i can learn a lot
Hi HS_Kim,
I was trying for a while and kept getting stuck on the attached image, trying to basically take these 3 squares, explode all the lines, and then split any segment that had a point through it. So in total there should be 12 segments at the end of the script. I tried various methods, but nothing gave me the exact result, I came close but not quite.
squarestosplit
I tried your script and it worked after I added the removal of duplicate lines (using Kangaroo), as you can see from the second image.
I was wondering if you could explain a bit how the data is being processed in your script, for example why do you need to Sort List or why some components need to be grafted.
I thought Shatter could easily solve my issue, but I played around with it for an hour and nothing worked. If anyone has a suggestion for a simpler script to achieve my goal I would appreciate it.
Thanks.
Take a look at the attachment…
SplitCurves_re.gh (10.7 KB)
Here is something universal
SMC.gh (12.6 KB)
Btw done with the help of @HS_Kim
Thank you! The logic of filtering for curves that are co-incident was very insightful.
Works as shown.
