I’d like to insert only blocks that exists in other file.
I import other file as blocks.(but I want to use entire file)
I can see parts blocks that exists in file in block manager by checking option (Reference block)
But I cannot select these parts blocks in “Insert” Command because they are not in Dropdown List box.
Hi Katsu- for now, Explode an instance of the top level block- the sub blocks will be available then as objects, and in the dropdown list for Insert. You can delete the exploded parts, they will stay in the available block list for Insert.
