How to inject input into anothers command's getter?
Rhinocommon allows nestable / transparent commands.
But how can I inject results back into to main command ?
what s the best practice ?
let s say my nestable command should mimic _distance command - how do inject the numeric result back ?
same for mimic _between how to inject point-coordinate ?
thanks - kind regards - tom
Hi @Tom_P,
The trick is that you don’t reach into the other command’s getter directly. A transparent/nestable command feeds its result back by typing it onto the command line, and the parent getter (GetPoint, GetNumber, GetDistance, …) parses that text as if the user had typed it. This is exactly how the built-in Distance command injects its value when you run it nested.
Mark your command transparent so it can run while another getter is active:
[CommandStyle(Style.Transparent)]
public class MyDistance : Command { ... }
Detect whether you’re running nested, and if so post the result via RhinoApp.RunScript.
  // ... get two points, compute the distance ...
  double length = a.DistanceTo(b);
  if (doc.InCommand(true) > 1) // we're nested inside another command's getter
    RhinoApp.RunScript(doc.RuntimeSerialNumber, length.ToString(System.Globalization.CultureInfo.InvariantCulture), false);
  else
    RhinoApp.WriteLine($"Distance = {length}");
  return Result.Success;
– Dale
thanks. :+1:
great - so this explicitly must not be a Script-Runner ?
therefore [CommandStyle(Style.ScriptRunner)] is not needed.
and for Point input like “_inBetween” ?
“RunScript” the Point to String with "G17" or "R" Format ?
or what is best practice to get full precision independend from document unit display precision ?
kind regards - tom
