How to get viewport bitmap of raytraced through Rhino common?
Hi @nathanletwory
Can you please explain to me how I can capture the viewport bitmap from Cycles with Rhino Common?
When I run this script that works for other display modes all I get is a white image. And it doesn’t matter if raytraced is running or not.
#! python 3
import scriptcontext as sc
import System
SaveFileName = rs.SaveFileName(title="File name", filter="JPEG (*.jpg)|*.jpg||")
if SaveFileName:
    print(SaveFileName)
    bitmap = sc.doc.Views.ActiveView.CaptureToBitmap()
    bitmap.Save(SaveFileName, System.Drawing.Imaging.ImageFormat.Jpeg)
I can work around this by using
rs.Command("-ViewCaptureToFile NumberOfPasses=1 " + save_path + " Enter", False)
And then read that file back in to python, but it is a slow workaround that I would like to avoid.
I use this script to do regression testing:
# Display regression script.
# Usage:
#     Set action to "setup" and run this script in the reference
#     copy of Rhino. This will generate a series of "* - reference.png"
#     files.
#     Then, set action to "test" and run in your target copy of Rhino.
#     At the end you will see "x of y passed tests" plus a list of all tests that failed.
#     All resulting images are in the "Results" folder.
#     To add test cases, add:
#         * 3DM files to the "Objects" folder. Objects in the model
#           that should have materials asigned must be named "material_target"
#         * DisplayMode.ini files to the "DisplayModes" folder
#         * Material.rmtl files to the "Materials" folder
#  IMPORTANT!!!
#     Make sure that ALL built-in display modes have been set to their defaults
#     in both situations (i.e.) Confirm they're at their defaults before running
#     "Setup" phase, and confirm they're at their defaults before running the
#     "Test" phase.  Since setup and test can be run at different points in time
#     and even on different configurations, it is impotant that you make sure
#     you're running regression tests using the EXACT same display settings...
#     otherwise, it's possible that some, or even all, tests will fail
action = 'setup'  # To be run in known "good" instance of Rhino.
#action = 'test'   # To be run in the Rhino to test.
#action = 'db'     # Setup or update the test database.
samples = 100
# match_amount controls how much the test frames must match the reference frames
# This number is the number of different pixels divided by the total number
# of pixels in the frame. When all are identical, this number is 1.000. When
# all are different, this number is 0.000. Frames must match more than this much
# for the tests to pass:
match_amount = 0.999
standard_res = (900,450)
high_res = (standard_res[0]*4, standard_res[1]*4)
import clr
clr.AddReference("System.Xml.Linq")
import System.Xml.Linq as xml
import os, math
import Rhino
import System.Drawing
import time
import itertools
import collections
import hashlib
import webbrowser
from Rhino.Display import ViewCapture
this_dir = str(os.path.dirname(os.path.realpath(__file__)))
model_dir = str(os.path.join(this_dir, "Objects"))
output_dir = str(os.path.join(this_dir, "Results"))
bgstyle = sc.doc.RenderSettings.BackgroundStyle # SolidColor, Gradient, Environment
programContext = Rhino.Render.RenderContent.ChangeContexts.Program
colEnvs = ["color1.renv", "color2.renv", "color3.renv"]
hdrEnvs = ["hdr1.renv", "hdr2.renv", "hdr3.renv"]
planarEnvs = ["planar1.renv", "planar2.renv", "planar3.renv"]
gpChoices = [
    (True, "shadows-only"),
    (True, "material"),
    (False, "disabled")]
envBgChoices = [
    (bgstyle.Environment, hdrEnvs[0]),
    (bgstyle.Environment, planarEnvs[0]),
    (bgstyle.Environment, colEnvs[0]),
    (bgstyle.Gradient, "gradient"),
    (bgstyle.SolidColor, "solid")]
custReflectChoices = [
    (True, hdrEnvs[1]),
    (True, planarEnvs[1]),
    (True, colEnvs[1]),
    (False, "no-custom-reflection")]
skylightChoices = [
    (False,"no-skylight"),
    (True, hdrEnvs[1]),
    (True, hdrEnvs[2]),
    (True, planarEnvs[2]),
    (True, colEnvs[1]),
    (True, colEnvs[2]),
    (True, "no-custom-skylight")]
sunChoices = [(True, "sun"), (False, "no-sun")]
possibleWorlds = [
    x
    for x
    in itertools.product(
        gpChoices,
        envBgChoices,
        custReflectChoices,
        skylightChoices,
        sunChoices)
possibleWorldsSha1 = hashlib.sha1()
possibleWorldsSha1.update("{0}".format(possibleWorlds))
possibleWorldsName = possibleWorldsSha1.hexdigest()
def irange(a, b):
    Range from a to b inclusive.
    return range(a, b+1)
def flatten(l):
    flatten a list that can contain nested lists.
    for el in l:
        if isinstance(el, collections.Iterable) and not isinstance(el, basestring):
            for sub in flatten(el):
                yield sub
        else:
            yield el
def test_ids(l, max):
    Generate index list from test ids. Can be used to generate broken sequences.
    ranges tests_to_run = test_ids([irange(1,3), irange(6,10)], len(possibleWorlds))
    will yield [1,2,3,6,7,8,9,10]
    ids = [x-1 for x in flatten(l) if (x-1)>=0 and x<=max]
    ids = collections.OrderedDict((x, True) for x in ids).keys()
    return ids
def colordiff(colora, colorb):
    a = Rhino.Display.ColorLAB(colora)
    b = Rhino.Display.ColorLAB(colorb)
    lsq = (a.L-b.L)**2
    asq = (a.A-b.A)**2
    bsq = (a.B-b.B)**2
    delta_e = math.sqrt(lsq+asq+bsq)
    return delta_e
def compare_images(a, b):
    '''Compare two System.Drawing.Bitmap images'''
    pixel_count = 0
    identical_pixel_count = 0
    errorbmp = System.Drawing.Bitmap(b.Width, b.Height)
    for x in range(0, b.Width):
        for y in range(0, b.Height):
            pixel_count += 1
            a_color = a.GetPixel(x,y)
            b_color = b.GetPixel(x,y)
            if a_color == b_color:
                identical_pixel_count += 1
                errorbmp.SetPixel(x,y, System.Drawing.Color.FromArgb(0,0,0))
            else:
                delta_e = colordiff(a_color, b_color)
                pcol = int(255.0 * delta_e)
                errorbmp.SetPixel(x,y, System.Drawing.Color.FromArgb(pcol, pcol, pcol))
                if(delta_e < 0.6):
    # Compute percent difference between two images
    return (float(identical_pixel_count) / float(pixel_count), errorbmp)
def capture_viewport(display_mode, resolution):
    view = sc.doc.Views.ActiveView
    if display_mode:
        Rhino.RhinoApp.RunScript("-_SetDisplayMode _Mode={0}".format(display_mode), False)
    else:
        Rhino.RhinoApp.RunScript("-_line 0,0 1,1 sellast delete", False)
        view.Redraw()
    vc = ViewCapture()
    vc.Width = resolution[0]
    vc.Height = resolution[1]
    vc.RealtimeRenderPasses = samples
    return vc.CaptureToBitmap(view)
def get_renv(name):
    name = name.replace(".renv", "")
    doc = sc.doc
    for e in doc.RenderEnvironments:
        if e.Name == name: return e
    return None
def xn(s):
    Shorthand for xml.XName.Get(s).
    return xml.XName.Get(s)
def xel(*args):
    Shorthand for xml.XElement(*args).
    return xml.XElement(*args)
true = "true"
false = "false"
def cleanpath(p):
    if os.path.exists(p):
        os.unlink(p)
class TestCase:
    TestCase represents a collection of settings that constitute one
    test case (or setup thereof).
    def __init__(self, id, model_path, action, display_modes, world, resolution):
        Initialize a new TestCase.
        id (int) - is a numerical rank index.
        model_path(str) - the path to the model to use for testing
        action (str) - either 'test' or 'setup'. Setup creates captures, test creates several captures and compares them with
                       captures created in setup.
        display_mode (str) - a string representing a display mode to test with
        world (tuple) - a tuple containing settings for the world
        resolution (tuple) - a tuple containing the resolution at which to create the capture at.
        self.id = id
        self.model_path = model_path
        self.action = action
        self.display_modes = display_modes
        self.world = world
        self.resolution = resolution
        sh = hashlib.sha1()
        _fnm = os.path.splitext(os.path.basename(self.model_path))[0]
        sh.update("{0}".format((_fnm, self.world)))
        self.name = sh.hexdigest()
        self.reference_image_name = dict()
        self.test1_image_name = dict()
        self.test1_error_name = dict()
        self.test2_image_name = dict()
        self.test2_error_name = dict()
        self.timings = dict()
        self.reference_compares = dict()
        for dm in self.display_modes:
            self.reference_image_name[dm] = "{0:06d}_{1}_{2}_{3}x{4}_reference.png".format(self.id, self.name, dm, self.resolution[0], self.resolution[1])
            self.test1_image_name[dm] = "{0:06d}_{1}_{2}_{3}x{4}_test1.png".format(self.id, self.name, dm, self.resolution[0], self.resolution[1])
            self.test1_error_name[dm] = "{0:06d}_{1}_{2}_{3}x{4}_error.png".format(self.id, self.name, dm, self.resolution[0], self.resolution[1])
            self.test2_image_name[dm] = "{0:06d}_{1}_{2}_{3}x{4}_test2.png".format(self.id, self.name, dm, self.resolution[0], self.resolution[1])
            self.test2_error_name[dm] = "{0:06d}_{1}_{2}_{3}x{4}_error.png".format(self.id, self.name, dm, self.resolution[0], self.resolution[1])
            self.timings[dm] = -1.0
        if len(self.display_modes)>1:
            combos = list(itertools.combinations(self.display_modes, 2))
            for combo in combos:
                pass
        self.bakefile_name = "{0:06d}_{1}.3dm".format(self.id, self.name)
        self.cf = -1.0
    def prepare_model(self):
        Load the model from filename. Environments (.renv) will be imported. The
        model will be changed according the settings given in world.
        The image name for the model will be returned.
        doc = sc.doc
        doc.Open(self.model_path)
        doc = sc.doc
        view = doc.Views.ActiveView
        if self.world:
            envdir = os.path.dirname(self.model_path)
            # import test environments
            for f in os.listdir(envdir):
                if not f.lower().endswith(".renv"): continue
                envimp = os.path.join(envdir, f)
                Rhino.RhinoApp.RunScript("""-_Environments
                Options
                LoadFromFile
                "{0}"
                Enter
                Enter
                """.format(envimp), False)
            doc.UndoRecordingEnabled = False
            # set up ground plane
            gpsettings = self.gp_settings()
            gp = doc.GroundPlane
            gp.BeginChange(programContext)
            gp.Enabled = gpsettings[0]
            gp.ShadowOnly = gpsettings[1]=="shadows-only"
            gp.EndChange()
            # set bg
            bgsettings = self.bg_settings()
            rendersettings = doc.RenderSettings
            rendersettings.BackgroundStyle = bgsettings[0]
            if bgsettings[0] == bgstyle.Environment:
                #print("setting environment to", bgsettings[1])
                doc.CurrentEnvironment.ForBackground = get_renv(bgsettings[1])
            else:
                doc.CurrentEnvironment.ForBackground = None
            # set custom reflection
            reflsettings = self.refl_settings()
            if reflsettings[0]:
                doc.CurrentEnvironment.ForReflectionAndRefraction = get_renv(reflsettings[1])
            else:
                doc.CurrentEnvironment.ForReflectionAndRefraction = None
            # set skylight
            skysettings = self.sky_settings()
            skylight = doc.Lights.Skylight
            skylight.BeginChange(programContext)
            skylight.Enabled = skysettings[0]
            skylight.EndChange()
            if skysettings[0]:
                skyenv = get_renv(skysettings[1])
                print("setting sky env {0} [{1}]".format(skysettings[0], skyenv))
                doc.CurrentEnvironment.ForLighting = get_renv(skysettings[1])
            else:
                print("no sky")
                doc.CurrentEnvironment.ForLighting = None
            # set sun
            sunsettings = self.sun_settings()
            sun = doc.Lights.Sun
            sun.BeginChange(programContext)
            sun.Enabled = sunsettings[0]
            if sun.Enabled:
                sun.SetPosition(120, 45)
            sun.EndChange()
        view.Redraw()
    def gp_settings(self):
        Get the groundplane settings from the world settings.
        return self.world[0]
    def bg_settings(self):
        Get the background (render) settings from the world settings.
        return self.world[1]
    def refl_settings(self):
        Get the custom reflection environment settings from the world settings.
        return self.world[2]
    def sky_settings(self):
        Get the skylight settings from the world settings.
        return self.world[3]
    def sun_settings(self):
        Get the sun settings from the world settings.
        return self.world[4]
    def gp_xml(self):
        Create ground plane XML representation for database.
        gps = self.gp_settings()
        g = xel(xn("groundplane"),
                xel("enabled", gps[0]),
                xel("shadows-only", gps[1]=="shadows-only")
#        g.SetAttributeValue(xn("enabled"), gps[0])
#        g.SetAttributeValue(xn("shadows-only"), gps[1]=="shadows-only")
        return g
    def refl_settings_xml(self):
        Create custom reflection environment XML representation for database.
        refl = self.refl_settings()
        r = xel(xn("custom_reflection"),
              xel(xn("use_custom"), refl[0]),
              xel(xn("reflenv"), refl[1])
        return r
    def render_settings_xml(self):
        Create render settings XML representation for database.
        rs = self.bg_settings()
        r = xel(xn("rendersettings"),
              xel(xn("backgroundstyle"), rs[0]),
              xel(xn("bgenv"), rs[1])
        return r
    def sky_settings_xml(self):
        Create sky settings XML representation for database.
        ss = self.sky_settings()
        s = xel(xn("skylight"),
              xel(xn("enabled"), ss[0]),
              xel(xn("skyenv"), ss[1])
        return s
    def sun_settings_xml(self):
        Create sun settings XML representation for database.
        ss = self.sun_settings()
        s = xel(xn("sun"),
        return s
    def reference_files(self):
        fs = [xel(xn("file"), xel(xn("display_mode"), dm), xel(xn("path"), self.reference_image_name[dm])) for dm in self.reference_image_name]
        rf = xel(xn("reference_files"), fs)
        return rf
    def xml(self):
        t = xel(xn("case")
             , self.gp_xml()
             , self.render_settings_xml()
             , self.refl_settings_xml()
             , self.sky_settings_xml()
             , self.sun_settings_xml()
             , self.reference_files()
        t.SetAttributeValue(xn("id"), self.id)
        t.SetAttributeValue(xn("code"), self.name)
        return t
    def test_single(self, display_mode):
        try:
            reference_image = System.Drawing.Bitmap(os.path.join(output_dir, self.reference_image_name[display_mode]))
        except:
            return 0
        Rhino.RhinoApp.RunScript("-_SetDisplayMode _Mode={0}".format("Wireframe"), False)
        Rhino.RhinoApp.RunScript("RotateView Left RotateView Right", False)
        time1 = time.time()
        image1 = capture_viewport(display_mode, self.resolution)
        time1 = time.time() - time1
        image1path = os.path.join(output_dir, self.test1_image_name[display_mode])
        cleanpath(image1path)
        image1.Save(image1path, System.Drawing.Imaging.ImageFormat.Png)
        time2 = time.time()
        image3 = capture_viewport(display_mode, self.resolution)
        time2 = time.time() - time2
        image3path = os.path.join(output_dir, self.test2_image_name[display_mode])
        cleanpath(image3path)
        image3.Save(image3path, System.Drawing.Imaging.ImageFormat.Png)
        f1_compare, err1 = compare_images(reference_image, image1)
        f3_compare, err2 = compare_images(reference_image, image3)
        err1path = os.path.join(output_dir, self.test1_error_name[display_mode])
        err2path = os.path.join(output_dir, self.test2_error_name[display_mode])
        cleanpath(err1path)
        cleanpath(err2path)
        err1.Save(err1path, System.Drawing.Imaging.ImageFormat.Png)
        err2.Save(err2path, System.Drawing.Imaging.ImageFormat.Png)
        image1.Dispose()
        image3.Dispose()
        err1.Dispose()
        err2.Dispose()
        self.timings[display_mode] = (time1 + time2) / 2.0
        sc.doc.Modified = False
        return (f1_compare + f3_compare) / 2.0
    def open3dm(self):
        doc = sc.doc
        fullpathbaked = os.path.join(this_dir, "Baked", possibleWorldsName, self.bakefile_name)
        doc.Open(fullpathbaked)
        print("opened", fullpathbaked)
    def setup_single(self, display_mode):
        Load given model from model_path, creating a capture in display_mode.
        The model is prepared with settings from world, and captured at resolution.
        Returns the full path to the image rendered.
        fullpath = ""
        #self.open3dm()
        #self.prepare_model()
        #Rhino.RhinoApp.RunScript("RotateView Left RotateView Right", False)
        start = time.time()
        image = capture_viewport(display_mode, self.resolution)
        self.timings[display_mode] = time.time() - start
        fullpath = os.path.join(output_dir, self.reference_image_name[display_mode])
        cleanpath(fullpath)
        print(fullpath)
        image.Save(fullpath, System.Drawing.Imaging.ImageFormat.Png)
        #return fullpath
    def create_3dm(self, root):
        Load given model from model_path, setting it up according the
        settings specified in world. The resulting model will be saved
        to the Baked folder for future reference.
        Returns the full path to the created file.
        fullpath = ""
        fwo = Rhino.FileIO.FileWriteOptions()
        fwo.IncludeBitmapTable = True
        fwo.IncludeRenderMeshes = True
        fwo.SuppressDialogBoxes = True
        fullpath = os.path.join(root, "Baked", possibleWorldsName, self.bakefile_name)
        cleanpath(fullpath)
        fullpathbak = fullpath+"bak"
        dirname = os.path.dirname(fullpath)
        if not os.path.exists(dirname):
            os.makedirs(dirname)
        sc.doc.WriteFile(fullpath, fwo)
        cleanpath(fullpathbak)
        return fullpath
    def html(self):
        info = ""
            info += r"""
            <td>
            <h3>{0:06d}: {1} : {2} seconds</h3>
            </td>
            """.format(self.id, dm, self.timings[dm])
        dmres = ""
            dmres += r"""
            <td>
            <a href="{0}"><img src="{0}" width="300" border="0" title="{1:06d}:{2} - {3} seconds"/></a>
            </td>
            """.format(self.reference_image_name[dm], self.id, dm, self.timings[dm])
        templ = r"""
        <table border="1">
        <tr>
        {0}
        </tr>
        <tr colspan="2">
        <a href="{3}">{1}</a>
        </tr>
        <tr>
        {2}
        </tr>
        </table>
        """.format(info, self.world, dmres, self.bakefile_name)
        return templ
    def do(self):
        Execute the action specified.
        if self.action == 'setup':
            self.create_3dm(this_dir)
        self.open3dm()
            if self.action == 'test':
                self.cf = self.test_single(dm)
                #if self.cf < match_amount:
                #    failed.append(model_path + ": {0}".format(cf))
                #else:
                #    passed.append(model_path)
            else:
                self.setup_single(dm)
def suite(all_cases):
    s = xel(xn("suite"), [t.xml() for t in all_cases])
    return s
def create_database(all_cases):
    s = suite(all_cases)
    print(s)
    return s
def run(action):
    display_modes = ['Raytraced', 'Rendered']
    #display_modes = ['Raytraced']
    start_all = time.time()
    all_cases = []
    run_cases = []
    worldcount = len(possibleWorlds)
    # all tests: tests_to_run = test_ids([irange(1,len(possibleWorlds))], len(possibleWorlds))
    tests_to_run = test_ids([irange(1,worldcount)], worldcount)
    # how to do different ranges tests_to_run = test_ids([irange(1,3), irange(6,10)], len(possibleWorlds))
    #tests_to_run = test_ids([irange(101, 200)], len(possibleWorlds))
    #tests_to_run = test_ids([irange(1,10)], len(possibleWorlds))
    #tests_to_run = test_ids([irange(worldcount-3,worldcount)], worldcount)
    tests_to_run = test_ids([129], worldcount)
    print(tests_to_run)
    for ttr in tests_to_run:
        print(possibleWorlds[ttr])
    # Throw away modifications in current document
    root = os.path.join(this_dir, "Environments")
    for file in os.listdir(root):
        if not file.lower().endswith(".3dm"):
            continue
        model_path = os.path.join(root, file)
        all_cases.extend([TestCase(i+1, model_path, action, display_modes, world, standard_res) for i, world in enumerate(possibleWorlds)])
        print(all_cases[ttr].world, all_cases[ttr].bakefile_name)
    #if action == 'setup':
    #    for file in os.listdir(output_dir):
    #        os.unlink(os.path.join(output_dir, file))
    if action == 'db':
    else:
        cnt = 0
                continue
            for t in tests_to_run:
                #world = possibleWorlds[t]
                cnt = cnt + 1
                #if cnt > 2: break
                test_case = all_cases[t]# TestCase(cnt, model_path, action, display_modes, world, standard_res)
                test_case.do()
                run_cases.append(test_case)
        total_time = time.time() - start_all
        resultshtml = os.path.join(output_dir, "results.html")
        with open(resultshtml, "w") as f:
            f.write("<html><body>")
            f.write("<p>{0} tests ({1} renders) completed in {2} seconds</p>".format(len(run_cases), len(run_cases) * len(display_modes), total_time))
            for tc in all_cases:
                f.write(tc.html())
            f.write("</body></html>")
        webbrowser.open_new_tab(resultshtml)
        runresultshtml = os.path.join(output_dir, "runresults.html")
        with open(runresultshtml, "w") as f:
            for tc in run_cases:
                f.write(tc.html())
        webbrowser.open_new_tab(runresultshtml)
    # Throw away modifications in current document, in case some were left
if __name__ == '__main__':
    if not os.path.exists(output_dir):
        os.mkdir(output_dir)
    run(action)
Ah, sweet. (strange stuff, but it works so I like it ;))
And I made a simple example here for others to use in the future.
#! python 3
import Rhino
import os
import System
def captureBitmap():
    # Check if realtimedisplay, get state and pause
    rtdm = sc.doc.Views.ActiveView.RealtimeDisplayMode
    if rtdm:
        pauseState = rtdm.Paused
        rtdm.Paused = True
    # Get view and capture bitmap
    vc = Rhino.Display.ViewCapture()
    vc.Width = sc.doc.Views.ActiveView.ClientRectangle.Width
    vc.Height = sc.doc.Views.ActiveView.ClientRectangle.Height
    # Ignore samples to capture current state
    #samples = 1
    #vc.RealtimeRenderPasses = samples
    bitmap = vc.CaptureToBitmap(view)
    # if realtimedisplay reset state
    if rtdm:
        rtdm.Paused = pauseState
    return bitmap
def runScript():
    # Save path
    #save_path = r"D:\temp\capture.jpg"
    save_path = rs.SaveFileName("Save JPEG", "JPEG (*.jpg)|*.jpg||")
    if not save_path: return
    # Ensure directory exists
    os.makedirs(os.path.dirname(save_path), exist_ok=True)
    # Capture bitmap
    bitmap = captureBitmap()
    # Save as JPEG
    bitmap.Save(save_path, System.Drawing.Imaging.ImageFormat.Jpeg)
    print ("Image saved to:", save_path)
runScript()
