Hello Rhino friends I’m running into an issue when trying to capture a viewport via RhinoCommon method
CaptureToBitmap
while using Windows RDP. It returns a blank black image, I’m assuming this is well known? Even the command ViewCaptureToFile
seems to have issues with this over RDP.
I saw this discussion about openGL over RDP and I’m wondering if it’s even possible to view capture on an RDP PC?
Here is my python code below if you want to try and reproduce. I’m just wondering if anyone has a workaround for getting this to work even if it’s relatively hacky?
Cheers!
Special thanks to @AndersDeleuran for the capture method from this post: A way to screencapture and send to print with one button? - #6 by AndersDeleuran
import Rhino
from System.Drawing import Bitmap
from System.Drawing.Imaging import ImageFormat
import os
import traceback
def capture_active_view(save_filepath, width, height):
Captures the active viewport and saves it to the specified filepath
Args
save_filepath (str): The filepath to save the image to
scale (float): The scale of the image relative to the viewport size (1.0 = 100%)
Returns:
str: The filepath of the saved image
None: If the image was not saved successfully
active_view = Rhino.RhinoDoc.ActiveDoc.Views.ActiveView
# capture image
try:
view_capture = Rhino.Display.ViewCapture(
DrawAxes = False,
DrawGrid = False,
DrawGridAxes = False,
Height = height,
Width = width,
ScaleScreenItems = False
image_capture = view_capture.CaptureToBitmap(active_view)
Bitmap.Save(image_capture, save_filepath, ImageFormat.Png)
if os.path.exists(save_filepath):
return save_filepath
else:
return None
except Exception as e:
tb = traceback.format_exc()
rs.MessageBox("An error occurred capturing the image: {}\n\nTraceback:\n{}".format(e, tb), 0|16, "Viewport Capture Error")
exit()
if __name__ == "__main__":
width = 800
height = 800
computer_name = 'your_pc_name'
image_path = r'C:\Users\{}\Desktop\test_img.png'.format(computer_name)
saved_filepath = capture_active_view(image_path, width, height)
if os.path.exists(saved_filepath):
rs.MessageBox("Image succesfully created: {}".format(saved_filepath), 0|64, "Image Saved")
