Hello, I would like to get the equally divided lines from a curve.
When i use divide curve, i can only get the separated point. please tell me the way to get the lines not the points.
Best,
Keisuke
Hello
Make a polyline with the points then explode the polyline.
hello laurent
Pretty good idea! very very thanks!
i tried that and well worked!
“lines” implies straight segments, which polyline will give you. But if you want segments of the original curve instead of straight lines, use the Divide ‘t’ output to Shatter the curve at the points.
