ct.rhino
(CT)
1
I think this evaluates the elevations at the control points of my Property Line polygon.
I am trying to calculate the average value of the spot coordinates and write that to a new level in the project for the average grade plane.
the “Type” selected is a custom type i created to show the elevation from the survey point:
ct.rhino
(CT)
2
I don’t think plugging in the toposolid was the right step either because it’s calculating the elevation of the bottom of the toposolid:
Moving the points up in Z above the surface didn’t help.
ct.rhino
(CT)
3
It appears I had to set the elevation to display Top elevation and now its working!
So the step I really need advice on is how to get this value into GH to calculate the average.
Japhy
(Japhy)
4
You can Get Element Parameters via the Element Parameter component.
