Hi All
can any one explain me here on how to extract “SIMILAR_ASSEMBLY” data from model ?
Can this be done through grasshopper or requires C# to get that info over to grasshopper.
Please guide me to right direction.
Regards
Hi All
Regards
Hi Any one ??
Hi Darozas, there’s this method:
Tekla.Structures.Model.Operations.Operation.GetSimilarNumberedObjects(selectedObject);
that can be put into a C# component.
Thanks @sebastian.lindholm ,
Got it sorted. Sort off
But results coming in incorrect
Have duplicate entries its pulling not same assembly’s in
private void RunScript(object selectedObject, ref object a)
// Cast the input object to the specific Tekla ModelObject type
var modelObject = selectedObject as Tekla.Structures.Model.ModelObject;
// Check if the cast was successful and the object is not null
if (modelObject != null)
// Assign the resulting collection to output 'a'
a = Tekla.Structures.Model.Operations.Operation.GetSimilarNumberedObjects(modelObject);
Regards
