I’m trying to get just the selected segment of a dimension string.
I can select it in Revit using the TAB key.
As you can see in the screenshots it will just give me the entire dimension string.
Thanks for your help
Rhino.Inside Revit: 1.28.9095.22044 (2024-11-25T12:14:48)
Rhino: 8.12.24282.07001 (Rhino 8)
Revit: 2024.3 (24.3.0.13)
CLR: 4.0.30319.42000 (4.8.9282.0)
OS: Microsoft Windows NT 10.0.22631.0
Japhy
(Japhy)
December 18, 2024, 2:20pm
2
Hi Lukas, We are looking at adding that in the near future, although no exact date on when it will be available for testing (Dev priorities…)
Hi Japhy, thank you so much!
This is now setting all segments of a dimension.
I just want to set ether a single segments of a dimension or multiple seperatly selected segments. (you can select seperat segments with the TAB key)
[image]
Do you see also see a way to achive this?
Maybe you can also point me to a good resource to getting started with the Revit API, Rhino.InsidenRevit and Python?
This would be a great next step for me to be able to exted some features myself.
T…
