How to get isotrim onto a trimmed surface
Hello, I am trying to add isotrim to these two surfaces in order to create panels ontop. However, I am aware you can’t do that because the surfaces are trimmed and isotrim only works on untrimmed surfaces.
NO plugins please!
Does anyone know any way I can get isotrim ontop of these surfaces?
FinalBuilding - Copy.gh (60.7 KB)
To avoid the hassle of seam, rotate the entire surface 180 degrees.
In addition to using the Isocurve component you can also do it this way.
Hello! Thank you so much for your responses! Do you think this way would allow me to add panels such as this on top?
Also, so sorry, but what is the range connected to? As well as the Iso curve? Because this is what I did and got this:
Also is there any way to keep the lines straight and not curved? Thank you for your help! I am a little new to this, so anything helps.
Hello, so sorry, but I am a little confused
Range is linked to a number, basically the number of Isocurves.
I attach the file.
The panels are made up of 4-point surfaces.
FinalBuilding - Copy a.gh (68.3 KB)
Thank you! I ended up just using trimesh as surface morph makes my computer completely crash. But thank you so much, I did end up with something quite similar!
