I have a surface patch obtained from a scan. I was trying to apply the isotrim feature and it seems to be working on the untrimmed surface rather than the trimmed. Is there a way to get around this? I have attached the surface file in .igs format.
I then tried the isotrim and it didn’t work either. I am trying morph what I have on the planar surface to the original. Is there a way. I am not sure if I am making self clear but really let me know.
I was saying that I require a smaller surface (highlighted in green) from the original surface that’s why I was trying isotrim. I want to achieve something like this
As you have shown your method will definitely work but I am having trouble with creating a sub surface off the original one. I hope this is a bit clear? Please let me know, thank you so much.
I am sorry but just having trouble sorting out the same surface with a hole. I am following your code and still understanding it. but cannot seem to get the same result for the hole. Probably the math.
BTW this is the original surface as mentioned in the above question, Original_Srf.igs (3.4 MB)
Really nothing from my side, I tried it all day and was not able to.
Hey, @Gaurav_Chauhan.
I’ve already gave you everything you need and It’s only a matter of a slightly different application.
And since this is not very parametric, you don’t have to do this using GH. You’ll get a much faster result with FlowAlongSrfcommand in Rhino.
I didn’t write you earlier, yeah I was able to achieve the above but am facing this new issue. Try your code with the two surfaces I have attached. The brep edges mess up. I can go in and manually fix it but can this be prevented? and why does this happen?
