As in topic there is method - https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Collections_ArchivableDictionary_Set_3.htm
But how to read it back? There’s no Get equivalent?
I think the [] operator should work.
string key;
GeometryBase gb;
ArchivableDictionary dict;
dict.Set(key, gb);
GeometryBase fromDict = dict[key] as GeometryBase;
if (null != fromDict)
// continue with deserialised geometry
https://developer.rhino3d.com/api/RhinoCommon/html/P_Rhino_Collections_ArchivableDictionary_Item.htm
Indeed thanks i didn’t though about that
@menno If this wouldn’t be a problem for you (as I saw you know a lot about serializing/deserializing stuff in Rhino) I would like to ask you how would you approach to serializing custom structure let’s say simplified example - something where you are nesting classes - like:
class Person
string Name;
List<Car> OwnedCars;
class Car
int ProductionYear
Engine CarEngine;
class Engine
double Capacity;
Read/Write in each? Approach to versioning / or just simplifying to dicts? Any other tips from your know-how?
Hi @D-W,
I would…
Have a look at the SampleCsCustomClass class in the SampleCsSerializeClass.cs out in the developer samples repository. Perhaps this will give you some ideas.
– Dale
Thanks @dale for input. To be honest i dont like serialization of this kind since as soon as class definition (fields) will change byte arrays will fail. I rather wonder how to keep it in dictrionaries since lack of key can be handled without any problem but this way i guess read/write everywhere won’t work i understand that archive dict without key or same key will overwrite previous. So top level should have read / write and nested ones should return then other arch dicts to nest them in top level dict?
I agree, which is why we encourage versioning your data.
Archivable dictionaries have their use. But there comes a time when you need a more control. Then it’s time to write and read your own user data.
– Dale
Yup i saw this earlier. I just wonder as sample says user data is attached to the object - should i use it as a guide also for doc data or rather lean towards simple/string doc data?
However i still cannot grasp how this clarifies my nesting “example”. Does UserData is the highest abstraction level for serializing and you just recommend it instead of operating on dicts?
Hi @dale I don’t know if I should continue this one or start new I’m occurring random issues when ReadDocument as you guided I made methods read/write for needed classes but those classes objects are registering to Doc events when created and I figured out that in most cases those registrations are lost for those objects not sure why more weird is that lets say in 20-25% of loads those are ok. Any ideas?
Solved. I lost track of events and missed the Dispose method to deregister those that’s why it failed on load. Reminder for future adventurers - be 100% sure you keep track of all registered events!
Yes please.
– Dale
No need my fault. As i updated above i didnt unregistered objects of one class from events so i had issues when those handlers cumulated. Fixed and its doing great and again thanks for tip on read/write inside classes it is doing its job perfect and is easy to maintain
