How to get a square mesh approximation for planar freeform surface
Hey guys,
I would like to get a square mesh approximation for planar freeform surface. so that u1 = v1
the panel shows the difference between the sidelength u1 and v1
Do you know a way?
The problem is that the underlying surface (untrimmed) of your shape surely does not have a common factor for width and length.
Maybe try to recreate a slightly larger rectangle, but with its length and width multiples of the size of your square.
I’m afraid that if you want an absolute square ‘tile’ you will not be able to do it just with Mesh Surface . You will have to use a little bit of maths.
erase.gh (15.3 KB)
