Hi All, i have multiple rails want to use different profile from the start and the end.
it works when there is one rail, but when there are multiple they merge.
can anyone help please. thanks
sweep.gh (21.2 KB)
sweep.gh (21.2 KB)
Is this the expected result?
If so, all you need to do is graft the rail input and the outputs of the two Orient components. Unless you do that, Grasshopper does not know which rail belongs to which sections. If that sound completely foreign, you should probably take your time and learn more about data trees…
sweep_graft.gh (34.9 KB)
Understood. thank you so much!
