How To Fillet Multiple Polylines at the Same Time?
Faster way to fillet multiple polylines?
From your “screenshot”, I would say CurveBoolean (to do all the multiple trimming and joining) then FilletCorners on the results.
Your solution does work but not exactly how I was hoping… thanks
Is there a way to use the _intersect command, group intersecting points and use those to fillet?
no, because two things have to happen.
  1. you need to trim the curves to be end connected and joined.
  2. you need to apply a fillet. (and spec a radius)
you can make a script for this, but personally I’d simply hot key those two commands and run them that way.
