how to erase/hide a this square, i just want only circle
Connect output circle to a curve component. Then hide the circle component.
The circle component requires a plane to draw the circle onto. That’s why it shows both
If you want to hide the planes in your preview, you need to determine which component is creating them and disable it’s preview. If you don’t know which component it’s coming from, select components and look for color change in the preview.
Not possible to determine what’s going on from your screehshot. If you want help in the future, it is always best to upload a grasshopper file.
-Kevin
