I couldn’t find Panelling tools using the package manager. Is there any way to install it on Mac Rhino 8?
Thanks in advance!
Hi Richard - actually, it should be installed by default on mac - I don’t have my mac here but I am told that is the case…
I couldn’t find it no matter what I tried. It’s quite disappointing.
It’s not in the PackageManager.
It’s part of core Rhino now.
Type “pt” and the PanelingTool command names will autocomplete.
In Rhino 8 > Settings > Plug-ins, you’ll find the native plug-in loaded.
Start Grasshopper, and you’ll see a Paneling Tools menu tab.
Never mind - I found it is Grasshopper
In Rhino 7 on MAC, I had Paneling Tools Menus. Now I can’t find where to find them.
I did install it through Package Manager in V8 when I couldn’t find my toolbars. I can’t find it in Toolbars or Panels under Window. I’m hoping I can still use the toolbars.
Is there any update on this? Do you have to use Paneling Tools with Grasshopper now? I can’t find a way to use the toolbars on Mac and don’t find all the same commands in Grasshopper.
Hi Heather,
You can access the commands by typing the command name (pt…) as it has been in V7.
If you’d like to access the toolbars, please download and use the attached.
Here are the steps to load the PanelingTools toolbar:
- Download PanelingTools.rui (450.4 KB)
- Go to Rhino8 menu → Settings…
- Under Toolbars - > File → Open 9and select the PanelingTools.rui
- Then check the “PanelingTools” checkbox
Please let me know if this helps.
Will investogate shipping the PanelingTools.rui with Rhino8 for Mac. Filed here…
Hi Alice -
That means that something on your machine or the network you are on is blocking access to the Package Manager.
You are posting this in a thread that is Mac-specific, but it looks like you are running Windows?
