How to do custom Arrowhead?
I would like to draw curves with custom arrowheads.
I know this can be partially done using the Leader and Dimension command. However, Leader only allows an arrow/block at one end of the line, which feels quite limiting. And Dimension only works on straight lines and feels quite limiting when it’s not actually about dimensioning.
It seems that it’s not possible to have a non-straight polyline with a custom symbol at each end?
Wouldn’t it be great to have the option to apply custom arrowheads made from user-defined blocks on any type of curves? From the Arrowhead command. This, combined with custom user text blocks, would open up nice possibilities for classical annotations.
Axis annotations could then be created more easily, as well as other, more complex types of annotations.
Thanks!
Pip
Hi Pip -
I put that feature request on the pile as RH-88187 Curve: Custom Arrowhead Request
