How to create physically Based Material with Python
Hi @DavidEranen, i’ve tried that but get the same as in your image. Actually if i copy the map from the displacement slot and paste it as instance into the bump/normal slot, i can see the proper normals for a nanosecond, then it changes to what you posted. Imho it should look like the picture @nathanletwory posted above using Raytraced.
Btw. can you explain the result when you use _ExtractRenderMesh on this sphere ? I see that the mapping changes and the rendermesh is undisplaced (after assigning eg. a new custom material). How would you extract the displaced mesh on the file Problem.3dm from above ?
Great, thanks !
_
c.
Hi @clement,
The reason it looks good at first and as time goes on the bump effect gets weaker is due to the following issue: https://mcneel.myjetbrains.com/youtrack/issue/RH-65842/Rendered-bump-texture-resolution-affects-bump-strength. It’s a combination of the fact that we are baking progressively higher resolution textures and the method we use to convert these textures into normal maps are sensitive to the resolution of the texture.
There’s no way to extract the displaced render mesh in this case, because the displacement happens during the rendering of the frame and therefore is part of the GPU shader code. Also, the displacement in this case is part of the material, not the object, so in that sense one could say it works as expected. We would need to do something a bit more fancy during ExtractRenderMesh to be able to bring the displacement along with the object itself. Of course, there’s always the “Displacement” object mesh modifier that you can use in the object properties. This one works differently, and will propagate through the ExtractRenderMesh command.
-David
Hi @DavidEranen, this is highly appreaciated. I think the user should be allowed to get (extract) what he sees on screen.
I would really like to use this feature, unfortunately it is no comparison to the displacement of the PhysicalMaterial. To reproduce what i see, please create a new sphere and apply the fbm texture using the Displacement modifier in Properties. I do get this user experience:
  1. Enable the displacement modifier to “On”
  2. Assign the fbm texture
  3. Wait 2 minutes or more
  4. Fail: “Displacement failed (mesh memory limit hit) - using default render mesh
  5. Change Mesh memory limit to 2048
  6. Wait 2 minutes*
The benefit of using the PhysicalMaterial is that i get instant updates when changing eg. the displacement distance. Thats why i’ve been so exited to use this new feature. Doing the displacement in the GPU (including tesselation) has a lot of potential, unfortunately the current implementation limits all benefits.
*I will make a separate topic about what happens after Step 6.
_
c.
Hi guys and @nathanletwory ,
I have adopted and modified this slightly for my use and wonder how I can assign this new material to an object through python. My issue is that sc.doc.RenderMaterials.Add(new_pbr) only returns True.
And if run the same script multiple times it just adds more materials with (1), (2) etc added to their names, so I can’t use name to identify the material either. Surely there is something simple I fail to understand so any help would be great.
import scriptcontext as sc
import System
import System.Collections.Generic
import Rhino
import os
def makeMaterial(filepathname):
    # split the filepathname into path and name, then split out the name without prefix
    imageName = os.path.splitext(os.path.basename(filepathname))[0]
    bmtex = Rhino.Render.RenderContentType.NewContentFromTypeId(Rhino.Render.ContentUuids.BitmapTextureType)
    bmtex.Filename = filepathname
    simtex = bmtex.SimulatedTexture(Rhino.Render.RenderTexture.TextureGeneration.Allow)
    # first create an empty PBR material
    pbr_rm = Rhino.Render.RenderContentType.NewContentFromTypeId(Rhino.Render.ContentUuids.PhysicallyBasedMaterialType)
    # to get to a Rhino.DocObjects.PhysicallyBasedMaterial we need to simulate the render material first.
    sim = pbr_rm.SimulatedMaterial(Rhino.Render.RenderTexture.TextureGeneration.Allow)
    # from the simulated material we can get the Rhino.DocObjects.PhysicallyBasedMaterial
    pbr = sim.PhysicallyBased;
    # now we have an instance of a type that has all the API you need to set the PBR properties.
    pbr.BaseColor = Rhino.Display.Color4f.White
    pbr.SetTexture(simtex.Texture(), Rhino.DocObjects.TextureType.PBR_BaseColor)
    # convert it back to RenderMaterial
    new_pbr = Rhino.Render.RenderMaterial.FromMaterial(pbr.Material, sc.doc)
    # Set a good name
    new_pbr.Name = imageName
    # Add it to the document
    result = sc.doc.RenderMaterials.Add(new_pbr)
    print (result)
filepathname = "C:\\path\\image.png"
Hi @Holo, just set it to the RenderMaterial property of the RhinoObject:
obj_id = rs.GetObject("Object", 4+8+16+32, True, False)
if obj_id:
    rh_obj = rs.coercerhinoobject(obj_id, True, True)
    rh_obj.RenderMaterial = new_pbr
    rh_obj.CommitChanges()
_
c.
So… this is all confusing…
I don’t need to add the material to RenderMaterials and can coerce a Rhinoobject that I can add the material to and then all is good? Geez this stuff is complicated. I just want to add an image to a terrain :slight_smile: :slight_smile:
I’ll try it out, but I know I will forget all about it unless I understand this stuff. (I will forget it anyway, but it will make it easier to fix any issues down the road though)
i totally agree with this. We need some updated rs like material handling methods.
Yes. I have a script which creates a render material and just assigns it to an object. This causes the render material to appear in the material browser.
_
c.
Thanks that did it!
I did have to add it to the document with sc.doc.RenderMaterials.Add(new_pbr) though. But then I could use the fix you sent me. (rh_obj.RenderMaterial = new_pbr)
So now I can download a georeferenced terrain and have it textured with an aerial from all over the country by a click of a button :smiley:
Christmas came early!
Now I save the aerial that is automatically downloaded, but could I just assign the downloaded bitmap directly without having it saved as a png first too?
Hi @Holo, i guess this is required if you want to save the Rhino file with the assigned texture residing somewhere on your harddrive. Is the downloaded bitmap in a different format which you cannot assign directly ?
_
c.
I guess it would work the same way just pasting a clipboard bitmap into Rhino? that bitmap isn’t stored on the drive is it? I just download a bitmap from a wms and then stores it as a png. (or what ever other format I would like) I do the same for the terrain from another wmas but then as a 32bit tiff and then read that in with it’s transfomationmatrix. It was complicated but now it works, so now off to the bugtracking and fixing.
Thanks for the help!
This script https://jesterking.github.io/rhipy/create_specific_rendermaterial.html I show directly assigning render material to the object without going through the rendermaterial table. I guess you followed https://jesterking.github.io/rhipy/create_pbr_material_with_textures.html as your basis - that I wrote to show you can add rendermaterials without assigning them to object which is something you can’t do with the old-style materials.
Anyway, you figured it out :slight_smile:
I hope that the scripts at https://jesterking.github.io/rhipy/ give you more insight into how these things work.
Yes, there’s some hoops to jump through with materials and all render content, unfortunately.
So a few years later I’ve returned to this post just with a c# implementation, which seems a little simpler now:
using Rhino;
using Rhino.Render;
RhinoDoc doc = RhinoDoc.ActiveDoc;
// Create new Rhino material and convert to PBR
var rMaterial = new Rhino.DocObjects.Material();
rMaterial.ToPhysicallyBased();
// Create simulated texture from image path
SimulatedTexture simtex = new SimulatedTexture(doc);
simtex.Filename = "C:\\Users\\tsrch\\Documents\\test.jpg";
// Assign texture to base color
rMaterial.PhysicallyBased.SetTexture(simtex.Texture(), Rhino.DocObjects.TextureType.PBR_BaseColor);
// Convert to RenderMaterial and add to document, this allows the material to show in the material editor
// without being assigned to any objects
var pbr = RenderMaterial.FromMaterial(rMaterial, doc);
pbr.Name = "testo";
doc.RenderMaterials.Add(pbr);
