Hi, I’m trying to create perpendicular frames to a polyline. For that I’m measuring the angle between each par of the lines and divide it by two. Everything works ok except the inner corners.
What am I doing wrong?
plyline perp.gh (15.3 KB)Hi, I’m trying to create perpendicular frames to a polyline. For that I’m measuring the angle between each par of the lines and divide it by two. Everything works ok except the inner corners.
plyline perp.gh (15.3 KB)I’m not 100% sure what you are trying to achieve, but maybe this could work for you?
plyline perp_V2.gh (18.7 KB)
Thank you! Looks like it should work, but I’ll check in Monday only.
So, it works but I don’t know why. I have took of the most of your additional nodes (frames for example) and still, it works.
