Hi all,
I would like to know how can I get a perpendicular frame in an specific point of a curve (e.g by ratio).
With perp.frames function, the minimum you get are 2 frames(in each extrem), and it is not my wish.
Thank you in advance.
Thank you!
I have a question here, I wanted to get a plane at a point from “curve closest point“ with parameter “t“ as in Perp Frame. But I wanted the x–axis of the plane must be parallel to global X-axis. Is the “align plane” would be the right way or any smarter method? Thaks.
I presume you want something like this? It’s a little ambigous as you don’t specify the direction for y or z…
aligned pframe.3dm (42.8 KB)
Yeah, you are right. Thanks for the help. I got it.
