Hello there!
I am a super beginner for grasshopper but I want to create 3D louvre facade with grasshopper, so i formed a surface with the two curves and isotrim it, however I have encountered some problems that the surface divided are not with equal ‘cross-section’. Would somebody please let me know how i can make it equal division of surface like shown in the photos? Thank you very much!!!
curvy louvre.3dm (1.1 MB) FACADE with two curves.gh (12.5 KB)
Your geometry is extremely far away from the origin and at a very large scale. Millimeters?
This gives you straight lines between the two curves which you can use to construct beams (or whatever you call them). Curves are internalized, no need for Rhino file.
FACADE with two curve_2021Jan15a.gh (10.1 KB)
You can use Contour
FACADE with two curves_.gh (7.6 KB)
yes it is in milimeter. Thank you so much!!! that helps a lot!!
Thank you so much!! Really appreciate it!
